It is currently Thu Aug 14, 2025 8:31 pm
 Post subject: Router cutter bearings
PostPosted: Tue Jul 14, 2015 9:22 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I have 5 rabbet bits, that are 1 1/4in wide I/m looking for source for 1 1/8 in bearings or metric OD 29.5mm to be used on the rabbeting bits. 1 is 1/2 in shank and 4 are 1/4in shanks . Does anyone have a source for these bearings.? I want to try them, to see if I can get a better cut than my current 1/4in spiral down cut bits .Thanks
PostPosted: Wed Jul 15, 2015 12:22 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Try routerbitworld, I know they have some bearings individually.
Also, CMT have a set which uses different size adapters for a common bearing.
PostPosted: Wed Jul 15, 2015 12:54 am
Is there a reason for not just using a stewmac or LMII system? I know shear bits are better technically, but we've done a lot of guitars with the LMII bits without trouble, good clean lines and precise cutting depths.
They are a bit more expensive, but they're designed for specific purpose, and they function well.
It seems to me that you could circumnavigate a whole lot of fuss by buying bits and bearings specifically designed to do exactly what you need.
PostPosted: Wed Jul 15, 2015 12:56 am
The bearings are also available individually, so if you don't feel like springing for the whole set, if you have a single binding depth you're after, you can just get the one bit and bearing. I think it's been 2 yrs since I've needed a new bit.
PostPosted: Wed Jul 15, 2015 7:11 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I have rabbet bits from LMI on my fixed ridgid rtr. and woodtek from woodworkers supply. But I want to extend the use of my other routers. I acquired a bunch of rabbet bits from a deceased woodworkers estate and would like to put them to use with the other rtrs that I have. They did not come with any bearings that can be used for loofery. I will start looking now, thanks for the suggestions . All the spare rabbet bits are 31.5 mm or ,1 1/4in wide . The bearings are 1 1/8in OD by 3/16in ID. If you know where I can find some ?? thanks
PostPosted: Wed Jul 15, 2015 9:37 am
First name: David
Last Name: LaPlante
https://ec.kamandirect.com/us/index.jsp ... v9fiv3x1dA
PostPosted: Wed Jul 15, 2015 4:00 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
thanks david I found a bearing think it/s LMI used it with the 1/4in rabbet cutter to get a depth of 5mm l and 2mm w on the ukes.If I want to make the binding thicker .I just come in with the 1/4in spiral down cut bit.
Users browsing this forum: DennisK and 29 guests
